jrai_common_mixins package
Submodules
jrai_common_mixins.cachable module
Base class for all classes with cachable methods. This is required for classes to work with the caching_property decoractor.
- class jrai_common_mixins.cachable.Cachable[source]
Bases:
object
- classmethod caching_method(*arg_cmps, _cm_maxsize=None, **kwarg_cmps)[source]
A decorator for class methods that cache results for subsequent calls.
Caution
This will internally store references to all arguments whenever the arguments are determined to be different from a previous set of arguments.
- Parameters:
cls – A subclass of this class.
*arg_cmps – Comparison functions for positional arguments. These must be functions that accept 2 arguments and return a boolean to indicate if the arguments are considered equal. If a function is None then arguments will be compared using the built-in id() function.
_cm_maxsize – The maximum number of cached results to store for this method. If None, no maximum is imposed. Values of zero or less are equivalent to None.
**kwarg_cmps – Comparison functions for keyword arguments. These must map keyword argument names to comparision functions as described for arg_cmps.
- Returns:
A caching method decoractor.
- classmethod caching_property(method)[source]
A decorator for class properties that cache results for subsequent calls.
- Parameters:
method – The method to convert to a caching property.
- Returns:
A caching property.
- clear_cached_method(name)[source]
Clear a specific method cache.
- Parameters:
name – The method name or the method itself.
- clear_cached_property(name)[source]
Clear a specific property cache.
- Parameters:
name – The property name.
- clear_old_cache_entries(by_atime=True, properties=None, methods=None, **kwargs)[source]
Clear old cache entries by age.
- Parameters:
by_atime – If True, clear entries with access times older thant he specified time, else clear entries with creation times older than the specified time.
properties – An optional list of properties to clear. If neither properties nor methods are specified then the entire cache will be cleared of old entries.
methods – An optional list of methods to clear. If neither properties nor methods are specified then the entire cache will be cleared of old entries.
**kwargs – Keyword arguments for creating datetime.timedelta objects to specify the threshold age.
jrai_common_mixins.registrable module
Base class for all registrable classes.
- class jrai_common_mixins.registrable.Registrable[source]
Bases:
object
Base class for all registrable classes, i.e. classes that can be defined anywhere and registered into a central class register for use by the internal components of this library.
To create a set of registrable classes, first devine a base class that derives from this class (e.g. EventMetric(Registrable), SequenceMetric(Registrable) and define a dict class attribute named _REGISTER in that base class. Define subclasses of that base class to create registrable subclasses.
- classmethod get_registered(name)[source]
Get a registered class.
- Parameters:
name – The name of the registered class, as returned by get_name().
- Returns:
The registered class.
- classmethod get_registration_base_class()[source]
Find the base class that contains the register. The base class should be a subclass of Registrable that defines a dict class attribute named _REGISTER (or whatever the value of _REGISTER_NAME is).
- Raises:
ValueError – Failed to find a registration base class.
- classmethod get_registration_name(from_register=False)[source]
Get the name of the class to use for registration. If the class’s name contains the registration base class’s name as a suffix, then the returned name will be the class’s name without this suffix. For example, a class named “L2Metric” derived from a registrable base class “Metric” will return the string “L2”.
If the class’s name does no include the base class’s name as a suffix then the full name will be returned.
- Parameters:
from_register – If True, check if the class already exists in the register and return the name under which it was registered. Use this to recover the names of previously registered classes.
- Returns:
The registration name.
- classmethod list_registered()[source]
List all of the currently registered names.
- Returns:
A list of the registered names, sorted alphabetically.
- classmethod list_registered_with_classes()[source]
List all of the currently registered names along with their classes.
- Returns:
A list of 2-tuples of names-classes pairs, sorted alphabetically.
- classmethod register(name=None)[source]
Register this class.
- Parameters:
name – An optional name to use when registering the class. If not used, it will use the value returned by
get_registration_name()
Module contents
Package stub.
